Battery Life
Car: 1983 Z28
Engine: 385 Fastburn
Battery Life
Here's a question for the folks who use their car sparingly (weekends, nice weather, etc.).
How old is your battery?
Mine is between 9-10 years old and still going strong. I keep thinking "I should probably replace it". It's a sealed unit from Duracell. I disconnect it whenever I park it in the garage, so the only time it sees use are the days I take the car out. Never used a tender on it.
Wondering if I should call Guinness or if this is common with cars that don't see much use?
Re: Battery Life
Car: 1985 Firebird & 1992 Camaro B4C 1LE
Engine: 310 LS1. & 305
Transmission: TH350 & T5
Axle/Gears: 9" 3.73
Re: Battery Life
We keep the batteries of all our vehicles that aren't DDs (11 vehicles plus a motorhome, so 18 batteries total) on Battery Tenders. We frequently get 12-15 years. out of them. Also, we swap out liquid acid batteries for AGM or lithium ASAP. Nothing worse than having a liquid acid battery fail on you and spew sulfuric acid fumes all over the cables.
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Battery Life
Hard to believe, I know, but the Interstate battery in my IROC is almost 14 years old. The car is always garaged, and in the Winter when I don't drive it frequently, I'll put a charger on it to keep it from going flat.
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Battery Life
The Deka battery in my F*ORD is 11 years old. It was 5 years-old before I started using a battery tender. Still going strong. The Deka battery in my Firebird is 4 years-old.
So far so good...
So far so good...
castro
Aug 16, 2017 01:33 AM
