Could the sending unit be bad if my Oil pressure gauge is stuck on max? Doesn't move at all on start Rev anything. On start up all gauages move. Temp gauge bounces to 220 then going back down at start but Oil doesn't move
Start with replacing the sender
sofakingdom
close
- Join DateSep 2005
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- CarYes
- EngineUsually
- TransmissionSometimes
- Axle/GearsBehind me somewhere
- Liked:2,454 Times in 1,874 Posts
Does it move with the key Off? Anywhere, at all?
If so, start even more basic.
Plug the wire back into the sending unit. Then go from there.
no doesn't move at all. I haven't driven ir in over a month because i was redoing rne carpet but before that it worled Originally Posted by sofakingdom
Does it move with the key Off? Anywhere, at all?If so, start even more basic.
T.L.
close
- Join DateSep 1999
- LocationColorado USA
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car'83 Firebird (T/A Clone)
- Engine350 with L-69 components
- Transmission700R-4, 2000 RPM stall converter
- Axle/Gears10-bolt/3.73 ..
- Liked:820 Times in 628 Posts
Replacing your carpet is what did it. I just replaced my intake manifold and now my tachometer doesn't work...
Quote:
right! 😆 Originally Posted by T.L.
Replacing your carpet is what did it. I just replaced my intake manifold and now my tachometer doesn't work... I was pegged all the way high. I replaced the sending unit still nothing. So I took off the gauage cover and adjusted the indicator down. It is working now but the reading is off how to I reset the gauage ?
Airwolfe
close
- Join DateOct 2020
- LocationFranklin, KY near Beech Bend Raceway, Corvette Plant and Museum.
- iTrader Feedback Score(11)
- Car1992 Pontiac Firebird
- Engine5.0L L03 TBI
- Transmission700R4
- Axle/Gears2.73
- Liked:675 Times in 515 Posts
Did you take the needle off and rotate it toward 0 psi and push it back on shaft or did you just manhandle the needle twisting it back toward 0 psi?
T.L.
close
- Join DateSep 1999
With no resistance (such as disconnected), the gauge should read past 60. If the sending unit is good and connected, the gauge needle should go to zero when the key is turned to the On (or "Run") position. If this does not happen, the gauge is bad...
