CVR gear reduction starter setup
Old Sep 15, 2024 | 08:06 PM
DanZ51's Avatar
Car: '86 Vette
Axle/Gears: 4.11
I've been running a CVR Protorque starter on my '86 Corvette for years now. First with the original DNE 4+3 (basically a Borg Warner Super T10), and then with a T56 with the reverse style Camaro clutch and flywheel. I recently swapped in an older 2pc RMS 400 block with a conversion Fidenza flywheel (mates an 2pc RMS engine to the Camaro clutch). Test fitting the starter I noticed the pinion gear stays stuck out (engaged) when I spin the motor over (no spark plugs in). I've shimmed to starter out several times from as little as .020 pinion clearance to .070 clearance (CVR recommends .025 - .060) It still stays engaged. I've measured the teeth between the old Camaro flywheel and the new Fidenza, they seem about the same. i have over 1/16" distance between the pinion and the flywheel when disengaged
I've read somewhere that on gear reductions starters the pinion likes to stay engaged until the engine starts. Is this true? Does the engine have to fire up to release the pinion?
Old Sep 15, 2024 | 08:21 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: CVR gear reduction starter setup
Thats the way mine works.
CamarosRUS
Jan 3, 2009 02:11 PM
dimented24x7
Dec 24, 2004 10:04 PM
PioneerCrazed
Jun 23, 2003 11:42 AM
Mike89GTA
Mar 19, 2003 03:07 PM
zboss86
May 22, 2002 04:32 PM
