got ministarter, have clearance issues.
Old Dec 11, 2004 | 01:52 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I bought one of those hitachi ministarters to replace the stock one. However, the pinion to ring gear clearance is off by a mile. They spec that it should be around .1" &#177 .040". Mine is at .250". Whats the deal? Is it jsut a mismachined starter block or is there something else that im missing?
Old Dec 11, 2004 | 07:39 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Sounds like its meant for a bigger flywheel/flexplate than you have - meaning - you have the wrong starter.
Old Dec 11, 2004 | 07:54 PM
Car: 88 Camaro SC
Engine: SFI'd 350
The distance that is the problem is the distance from teh rear face of the ring gear to the front face of the pinion gear with the starter disengaged. Heres what Im talking about:
Old Dec 11, 2004 | 07:59 PM
Car: 88 Camaro SC
Engine: SFI'd 350
With both of the supplied shims the backlash was ok, but the starter seems too be too far away from the ring gear on the flexplate. The flexplate itself is yer basic chevy 153 tooth flexplate and I dont see any external problems with it. With the starter engaged, there doesnt seem to be much of the pinion engaged with the flexplate. Id be afraid to actually use the thing.
Old Dec 11, 2004 | 11:55 PM
Air_Adam's Avatar
Ok... I misunderstood before
I dunno what to say, I can't really help you, but I'll bump it up for ya
Old Dec 12, 2004 | 12:06 AM
Car: 88 Camaro SC
Engine: SFI'd 350
I really wish I knew what the problem is. The thing is way off but everything else looks ok.
Old Dec 12, 2004 | 10:37 PM
Car: 88 Camaro SC
Engine: SFI'd 350
I checked everything out. The block looks fine, the flexplate looks fine, the holes appear to be in the right spot, so it must be the starter.
If the next one I get has teh same problem, I guess Ill be rocking out another stock boat anchor delco starter
Old Dec 13, 2004 | 07:44 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
you could also buy an LT1 starter. nice and small and light. turbobuicks.com had the cheapest price around.
Old Dec 24, 2004 | 02:45 PM
Car: 88 Camaro SC
Engine: SFI'd 350
I found the problem. I was watching the flexplate (semi-new one for 2-piece RMS) while the motor was running and the ring gear looks like it was welded on by stevie wonder The flexplate itself is ok but the ring gear is way off. It also wobbles so its not centered, either. Who makes these things?
Old Dec 24, 2004 | 03:06 PM
Damon's Avatar
Sounds like the flexplate has, um.......... "flexed" once too many times. Aftermarket stuff often comes from China these days. Get used to it, that's the new home of cheap manufacturing. I would think that a used factory part from a junkyard would be an easy score. If the teeth aren't chewed up and the hub doesn't have obvious cracks it should be good.
Old Dec 24, 2004 | 03:07 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
If you got lt1 starter, screw that. You cannot buy them new anymore and you will be getting a rebuilt lt1 starter. Get a LT4 starter, you can buy them new from, gmpartsdirect.com and they are higher torque and weigh about a lb less than the lt1 starter. They fit the same way and a tad shorter, perfect starter, much easier to start the car with.
LT4 Starter part #:
10455709
Old Dec 24, 2004 | 10:04 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Im just using the direct drive boat anchor for now. I put it back in after the ministarter thing fell apart. I returned the one I bought. When I get around to it Ill pull the trans back and put a good flexplate in so I can run a decent starter. I had the trans out but it didnt occur to me to put in a decent flexplate since mine is only a couple of years old.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
armybyrd
Oct 24, 2015 06:59 AM
91 SrS
Oct 7, 2015 04:32 PM
Shane87irocz
Sep 22, 2015 06:21 PM
skip91
Sep 22, 2015 10:25 AM
