Does the Ignition Coil need to be Grounded?
Old Dec 24, 2004 | 08:55 AM
Luder[PAK9]'s Avatar
Car: 1991 Camaro RS
Engine: 3.1L V6 MPFI
I replaced my ignition coil recently. Rather than dealing with removing the rivets on the old coil so I could mount the new one, I just have the new one dangling by the wires. (It is ziptied in place, though, so I don't lose it going down the road). Besides looking ghetto, is there any problem with this? Does the coil need to be grounded at all?
Old Dec 24, 2004 | 12:34 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I really don't know the V6 setups at all, but if it is a coil-in-cap design like the V8's, the coil has a metal ground strap that grounds the coil. In otherwords, no, there is no actual ground wire that you have to hook up.
Old Dec 24, 2004 | 03:08 PM
Damon's Avatar
Technically, yes, it should be grounded. However, I have run coils many times "hanging from a ziptie" like you and never killed one. I never ran them for years on end like that, but over a period of months, never a problem.
Old Dec 24, 2004 | 04:22 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
i asked this same ? to the techs at MSD the other day and i was told "NO". i called them to discuss my ignition problems and that was one ? i had for them because i had a questionable ground.
KAM
Old Dec 24, 2004 | 11:34 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
On the ones Ive encountered, the coil is self contained in a plastic/resin housing and the iron core passes through that. I dont think there is any contact at all with the metal chassis of the coil.
Hotrodboba400
Dec 10, 2019 07:07 PM
skeltor
Feb 2, 2016 10:37 AM
billybob6110
Sep 23, 2015 01:30 PM
Glowsock
Sep 5, 2015 07:48 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
