1985 Z28 Temp Gauge gets stuck on start
Old Feb 2, 2025 | 10:49 AM
pcopp's Avatar
Car: 1985 Z28 TPI 305
Engine: 5.0L VIN F TPI
Transmission: 700 R4
Axle/Gears: 3:23
So I have a problem with my temp gauge - pegs max on start and needle gets hung up on the gauge face bezel.
I pulled the gauge and bench tested it. Using different resistors on the sending unit terminal, I get the correct face reading.
For example, with a 100 ohm resistor and a 12V power supply, I get 220deg F needle position. With a 47 ohm resistor I get 260.
FSM says 55 ohms is 260deg F and 1385 ohms is 100deg F.
On my bench, with the resistor hooked up, if I ground the sender unit lead (like what happens on startup), the needle pegs out and gets stuck on the gauge face bezel.
I tried pushing the needle down or slightly bending the tip. It works a few times then gets stuck again.
When I install the gauge back in the car/cluster, in the run mode, with a cold car (20 deg in NJ this am) it is held at 100 deg on face. When I hit start, it immediately pegs and gets stuck, just like on the bench.
My son has a 1986 IROC and on start, the needle gently sweeps up and down on ignition start. His does not get stuck.
Any ideas what I can do or what my problem is?
Old Feb 2, 2025 | 05:32 PM
pcopp's Avatar
Axle/Gears: 3:23
Re: 1985 Z28 Temp Gauge gets stuck on start
So I took a grinding wheel and relieved the edge of the gauge so the needle does not hang up when I start the car. I am working on the motor now so did not get it up to temp. It's very cold in NJ. I plan to adjust the TPC and possibly change the IAC so when I get the motor warmed up, I will know if the sending unit is working.
If anyone has experienced the needle hanging up on startup, let me know how/if you addressed it.
LetzRoc1989
Aug 29, 2020 10:19 PM
st1100man
Nov 29, 2009 01:05 AM
darrel88
May 27, 2006 07:29 AM
chuck88iroc
Apr 19, 2004 07:59 PM
tpirocz
Sep 19, 2002 06:44 AM
