Left turn signal keeps blowing a fuse
Old Feb 23, 2025 | 12:31 PM
Gungy's Avatar
I have a 1985 z28 camaro, and whenever I use the left turn signal it blows the corresponding fuse. However the hazards work just fine and every other light functions normally. Im not very well versed in electrical issues, ive tried replacing the flasher and hazard relay, as well as the bulbs on the front and side and still no luck. Any suggestions for fixes would be greatly appreciated.
Old Feb 23, 2025 | 03:36 PM
exiled350's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 427ci Gen 1 Small Block
Axle/Gears: Strange60 4.10 Eaton Truetrac
Re: Left turn signal keeps blowing a fuse
Turn signal switch is probably grounded to the column somehow.
Old Feb 24, 2025 | 07:15 AM
Yup, probably a chafed wire in the column.
The harness is part of the switch. Just change it out.
MSgt Luttrell
Apr 30, 2015 05:15 PM
robster66
Jan 8, 2008 09:17 PM
rockandroll1977
Jun 9, 2004 05:07 PM
makinemtap
Jul 31, 2001 08:14 PM
