Had a question about odometer stuff
Old Feb 25, 2025 | 09:06 AM
Vhanta97's Avatar
Car: 1984 Camaro Berlinetta Starship Ed.
Engine: Worn out SBC 305 5.0L V8
Axle/Gears: Stock
I have a 1984 Berlinetta Starship. I just put in a new digital gauge cluster and saw that the mileage reads around 240k miles. There is a on board computer in it that isn't original to this car, but I'm not sure how the odometer system works in this car. So I'm wondering if that mileage is accurate to this car or pulled from the computer?
Old Feb 25, 2025 | 10:28 AM
John in RI's Avatar
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Had a question about odometer stuff
Odometer mileage is stored in the Speedometer cluster. This picture shows the back of the Digital cluster,...... the ROM chip visible in the small "window" on the back of the cluster is the Odometer chip. You can remove this chip from the original cluster and install it into the replacement cluster to retain an accurate odometer reading after a cluster swap.
25thannivZ28
Oct 22, 2017 09:03 AM
ricklovin93
May 22, 2012 10:34 PM
hardon85
Oct 29, 2009 04:52 PM
TenaciousDB
Feb 26, 2002 11:02 PM
