aftermarket gauge cluster
Old May 13, 2012 | 09:16 PM
ricklovin93's Avatar
Car: 1988 camaro base coupe
Engine: 305 LO3
Transmission: gm 700-r4
like this,http://www.rickscamaros.com/camaro-d...1982-1989.html
what do i do about the odmeter, how can i make the new odometer match what my old odometer shows?
Old May 13, 2012 | 09:19 PM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Re: aftermarket gauge cluster
The new Dakota Digital VHX instruments are cheaper, has more functions and look better.
Old May 13, 2012 | 09:20 PM
Engine: 305 LO3
well still the whole odometer question is still in play with thoses as well
Old May 13, 2012 | 09:50 PM
peterc005's Avatar
Transmission: T700
With the Dakota you can reset the odometer when you first get it.
Old May 13, 2012 | 10:14 PM
Engine: 305 LO3
Wht about the auto meter gauges like the ones I posted how do I set the ofmeter
Old May 22, 2012 | 10:09 PM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
I built my own for the cost of gauges. https://www.thirdgen.org/forums/fabr...-build-my.html
Old May 22, 2012 | 10:34 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Go here and download the instruction sheet. Maybe it'll answer your question.
http://www.summitracing.com/parts/ATM-4488/
tommy z-28
Oct 6, 2015 10:58 PM
customblackbird
Oct 1, 2015 04:30 PM
Stryker412
Sep 20, 2015 06:59 PM
Trevor Tarry
Sep 15, 2015 02:04 AM
TrevinE
Sep 14, 2015 03:20 PM
