Unplugged wire in tail light cavity
Old Jun 7, 2025 | 06:48 AM
MTMiii's Avatar
Car: 1987 Trans AM
Engine: 305 Carbureted
I opened up the tail light cavity and found a few wires unplugged, hopefully they aren't unplugged because they short something out. I got most of them plugged in where they need except for one, anyone know exactly where this specific wire plugs into? Thanks!
Old Jun 7, 2025 | 09:02 AM
bennettcvcu's Avatar
Car: 1988 IROC-Z
Engine: L03 to L05: 350 TBI
Transmission: MD8: 700R4
Axle/Gears: GU2: 10 bolt/2.73
Re: Unplugged wire in tail light cavity
It either goes to the cargo compartment light assembly or the cargo compartment light switch. Both should be behind the insulation mounted to the rear interior cover just right of your hand. Either, yes, a short but most likely disconnected by accident when reassembling.
Old Jun 7, 2025 | 11:50 AM
MTMiii's Avatar
Car: 1987 Trans AM
The cable is too short to reach that light. It has to connect to something quite close to it. It's possible it isn't factory, maybe someone has images of the wiring back there and all the connectors, or something like that.
Old Jun 7, 2025 | 06:29 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
The switch should have the other half of the pigtail. Hard to see in this pic, but its green and (i think) brown w/ wht tracer. You should have a pair of male/female plugs. If you done have the cargo light. Then your connector goes to the brn/wht wire. which should have the female plug.
Old Jun 7, 2025 | 08:04 PM
MTMiii's Avatar
Car: 1987 Trans AM
I must not have a stock door hatch in here because mine does not look the same. Maybe it’s just a different model? This is what I see in the back of mine
Old Jun 7, 2025 | 09:41 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Maybe its got something to do with mine being a vert, idk. Its probably not used in your application.
Old Jun 11, 2025 | 10:31 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I *THINK* it's a trigger switch for interior courtesy/dome lighting.
IIRC not all cars had a plug on the car/body harness to plug it into. I'm thinking it was used on 89+ cars ???
PLEASE - correct me if I'm wrong here !
Trans AM GTX
Jan 30, 2020 01:48 PM
Stratus0202
Aug 3, 2016 05:56 PM
formula forever
Nov 22, 2005 07:01 PM
Nightcruzer
Sep 7, 2001 07:55 AM
