Odometer and trip meter not working.
Car: Firebird
Engine: 305 TBI
The odometer and trip meter have stopped working and I am getting ready to try and fix it and I am wondering where I should start. Both my tachometer and speedometer work perfectly fine. The only gauge that doesn’t work is the oil pressure gauge which I hope a new sending unit will fix. I just don’t want to go tearing stuff apart without some peoples input. Thanks!
Car: 86 trans am
Engine: 383 w true duals
Transmission: t56
Re: Odometer and trip meter not working.
sounds like the gears broke in the cluster to me. its pretty easy to replace, therye just plastic gears that drive it. you can find replacements on ebay. make sure you dont interchange the gauge needles when you take them off, itll mess up the readings for some reason
heres a write up
Microsoft Word - 1985-1992 Firebird & Trans Am Odometer Gear Replacement
Odometer Gears - Pontiac - Firebird-Trans Am
heres a write up
Engine: 4++,350 & 305 CIs
