why is my oil pressure gauge pegged
Old Sep 17, 2002 | 07:00 PM
zee28's Avatar
Car: 86 iroc
I just switched from a 85mph speedo cluster to a 145mph cluster and everything works fine except the oil pressure gauge pegs as soon as I start the car.is this a bad gauge?thanks for any help.
Old Sep 18, 2002 | 07:50 AM
Jyrx's Avatar
Car: Firebird
Transmission: th700
The wire that is comming from the oil sending unit isnt connected to the gauge correctly. Your bad connection could be behind the gauge. This happened to me once, but my bad connection was near the sending unit.
Hope this helps!
Old Sep 18, 2002 | 08:29 AM
zee28's Avatar
Car: 86 iroc
yeh Im gonna check the connection at the sending unit.Before swapping the gauges I was by the sending unit re-routing my plug wires,maybe I hit something.thanks
Old Sep 19, 2002 | 11:39 AM
JohnTheBull's Avatar
Car: 1991 Firebird
Engine: 3.1L
Transmission: Stock
Axle/Gears: Stock
Mine is usually pegged too. But its all original. Havent changed anything. Ive had the car about 10 years and it has always been that way. I turn it on and the oil pressure almost pegs out. I hit the gas and it hits the peg.
Its a '91 Firebird. 3.1L v-6. 270,000 original miles. I use to worry about it, but never could figure out what, if anything, was wrong.
Old Sep 19, 2002 | 12:09 PM
zee28's Avatar
Car: 86 iroc
Mine was just the connector knocked off,I figured it out last night.the blade that makes the connection inside the rubber boot had pulled out.all fixed now.thanks to the person who mentioned this.If yours pegs when you hit the gas,you have another problem,maybe the sending unit is bad?not sure
Old Sep 19, 2002 | 12:47 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Gm is known for bad oil sending units, look into getting a new one if it pegs when you hit the gas. It should move some, but not peg out.
Old Sep 23, 2002 | 12:23 AM
racerx004's Avatar
If I read his post properly he said his gauge almost pegges out, then completly pegs when he hits the gas.
Sounds like a bad gauge to me.
Old Sep 26, 2002 | 04:10 PM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
Maybe some of y'all just have really good oil pressure????
Old Sep 26, 2002 | 11:11 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
Try replacing the oil pressure sending unit yet?
It's right next to the dist, on the back of the engine..
Costs about $15...
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
