wireing diagrams
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
wireing diagrams
dose anyone have a complete wireing diagram set (preferably the color one I saw somewhere)for an 84 camaro, the austinthirdgen ones are for later models and trans-ams, which have diffrent lighting, and the autozone links are broke, my hays/chilton manuals are nowhere to be seen (and are aparently no longer avaiable at local parts houses). I decided to take my camaro out of storage and it looks like mice got into the wireing, they really went after the lighting, its doing all sorts of screwing things, and I cant find a set of early 3rd gen W/D, there all later ones with DRL's or Firebird ones with the diffrent light combos....also I remember someone had color ones but I cant remember where if someone has those links that would be awesome.
-Mark
-Mark
Transmission: T-5, TH350, T-5
Re: wireing diagrams
I'd honestly suggest just getting a fsm for it in which case. Lifesaver when you can dig through the multiple pages in a book.
https://www.themotorbookstore.com/19...op-manual.html
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
This is a FULL collection of diagrams from the 85 Camaro,..... If your car was originally a V8 Carb car than MOST of the wiring should match your 84.
https://berlinetta.info/DigitalCamaro.zip
