looking for an upgraded Negative battery cable
Old Dec 22, 2025 | 05:25 PM
cs80camaro's Avatar
Car: 1987 Iroc Z
Hello all,
Looking to update my failing stock OEM negative ground cable. I was looking for a bigger gauge cable instead of getting another stock one.
1987 Iroc Z28
305 TPI auto
So far i have just need the ones on hawks but i need to buy the set. Does anyone else still sell these for our cars?
Thanks,
Colin
Old Dec 24, 2025 | 08:12 AM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Re: looking for an upgraded Negative battery cable
Buy some welding cable and make yourself a new ground cable
Old Dec 25, 2025 | 09:23 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
You can buy welding cable, ends, and crimp tool on amazon.
Old Dec 25, 2025 | 09:25 PM
thatsupnow's Avatar
Just have to make sure it's actually OFC welding cable. A lot of the stuff in Amazon is CCA cable which is junk
Old Dec 25, 2025 | 11:58 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Don't even need a crimp tool. Heat the ring connector receiver w/a propane torch, fill it w/solder, stuff the stripped wire end into the solder, pull the torch away and let cool. Sleeve the ring connector receiver and about 4" of the cable w/heat-shrink for a pro look.
Old Dec 26, 2025 | 06:43 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
^^^^This.
A home-made cable---done correctly---will be much better-quality than a "parts store" generic cable.
Nova73
Aug 26, 2020 06:59 AM
my82roc
Aug 15, 2015 08:02 PM
