under hood light bulb
Car: 84 z
Transmission: 700
Axle/Gears: auto overdrive
found the overnight battery drain. hood light on this 84 was saying on, pulled fuse but any ideas on tracking down the cause. Thanks
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: under hood light bulb
Yeah, the switch on thelight is bad, so the light stays on all the time...
Parking on a hill, bracket is bent, ... it's a tilt switch. REAL basic. You can figure it out.
Or, just unplug it and move on, since it about as useless as **** on a chicken, anyway.
Car: 1984 Trans AM
Transmission: 700-4r
I had same problem on an 1980's Mercury Capri. the under hood light stayed on after hood closed. Just disconnected it. Problem solved
