Hood light
Old Sep 23, 2004 | 08:57 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Hood light
Where is the sensor that turns the hood light on and off?
I have had a dead battery a couple of times now, and I think its because of the hood light (which had no light in it when I bought it).
While the hood is up, I just thought I would fix it, wherever it is.
Another post says that it is in the light itself. How does that work?
Old Sep 23, 2004 | 09:13 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It operates on a mercury switch built into the light assembly. :lala: :lala:
Old Sep 24, 2004 | 06:22 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Which frequently fails, and leaves the light on at unexpected times, and causes the infamous mystery dead battery syndrome.
I leave mine unhooked except when I'm actually using it.... which is like both times I've needed it for as long as I've owned the car. One of my other cars used to have mystery dead battery, and it turned out to be the same thing, except it was the trunk light, which works the same way.
Old Sep 24, 2004 | 08:40 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
You could always put a toggle switch in the line to the battery so that it would not come on until you flipped the switch.....
Old Sep 24, 2004 | 09:38 AM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Cool idea.
But just more switches and other crap under my hood. MSD box, flex-a-lite fan controller, fuse box, hood light switch.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
LittleFranks
Aug 20, 2015 03:55 PM
Omega
Aug 10, 2015 12:46 PM
