How do i fix this dome light problem
Old Feb 2, 2002 | 12:14 AM
Convert's Avatar
Car: 1987 Iroc Z
Engine: 5.7L TPI
When i open my passenger side door, the dome light goes on. But, when i open my driverside door, nothing happens. It used to work, but the car was sitting for a few years. Maybe the little pushbutton thingy in the door jam broke??? How do i fix or troubleshoot this? :lala:
Old Feb 2, 2002 | 01:43 AM
Jza's Avatar
Jza
You pull the plastic panels (the screws are hidden in the carpet if you got the deluxe option) and get to the wires going to the door pins. Use a multimeter on the wire/ground and see if there's continuity when the switch is "out" and if it cuts out when you push it in. If not, follow that wire back and look for a break somewhere.
TheJoeY88
Dec 31, 2016 07:30 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Omega
Aug 10, 2015 12:46 PM
