Right turn signal indicator stays on and tach/battery gauge fybared....
Old Feb 5, 2002 | 11:01 PM
IROCME's Avatar
Car: 1986 IROCZ
Engine: LB9....rebuilding coming soon
Transmission: rebuilt 700R4
It does it sometimes,and not then other times,now my tach is stuck at 7500 rpm,any idea what could be causing this,when my tach and battery guage die the right turn indicator in my gauge pod lights up and will not go off unless I turn off my lights,its annoying at night,any idea what this could be????
Old Feb 6, 2002 | 01:00 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Make sure the gruond to the lights are clean & tight.... it can do some very odd things if not (including making your car idle bad/odd when the lights are on)
The grounds come thru the hole in the rad. support & grond to the upper part of it.
A bad drivers side light ground plagued me (gauges, turn signals & running) for the longest time till I hunted it down with a DMM (multi-meter)
Of course...you may have a worse problem that just a bad ground....
Old Feb 6, 2002 | 11:20 AM
IROCME's Avatar
Car: 1986 IROCZ
if I jack up the front of my car and look unerneath where would it be again,pics??what should I cle the ground with???metal file and alcohol??does it disconnect with a screw???it is the drivers side turn signal....
Fronzizzle
Mar 18, 2019 08:29 PM
LittleFranks
Sep 17, 2015 12:22 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
