Electrical or Carb problems ??
Old Feb 11, 2002 | 01:19 AM
triplediver's Avatar
After changing out my Quadrahog carb. and installing an Edelbrock performer carb, as well as changing out the distributor with a non cc version, and also blocking off the EGR valve port in my intake. I have project TA running but am having a serious problem with it, the only way that it will run is with the choke almost completely closed and the RPM's running around 2000 - 2250 . The motor is in time and the carb has been properly adjusted, I have also replaced all vacuam lines and cannot find any type of vacuam leak anywhere. This motor is a 305 in an 85 T/A with an automatic tranny. As always I thank you in advance for any and all replies.
Infested
May 22, 2018 11:56 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
