No reverse lights or E-Brake Dash light
Old Feb 11, 2002 | 09:47 AM
deadtrend1's Avatar
Since i bought the car a year ago, i never can get the reverse lights working. And, when i start the car, the Brake light on the dash lights on like it should for a second and goes out, but when i pull the lever up .. it never comes on. I have a 5 speed manual and i tore everything aprt looking for the wires and plugs. Went under the transmission and made sure the 2 plugs are connected, but no prevail. Anyone know what makes the lights go on???
Old Feb 11, 2002 | 09:02 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
Okay I'll start from the top. Is the reverse light switch good? You can take a voltage tester in front of and behind it to make sure power is being transmitted through. If there is no power behind it and there is before than the switch is bad. If the power goes clear through trace it back to the hatch where you can find it in a connector with the fuel gauge under the locking storage compartment. See if you're getting power there. Just do this 'til you isolate it. Mine don't work either and I can't find any wires in the console that go to it. The wire going into the switch should be dark blue and the wire leaving should be a light green. This will run to that connector in the hatch. For the parking brake, there should be a tan or white wire leading from the switch to the cluster.
These electrical problems are often hard to locate, Good Luck!
-Matt
Jk_Under
Sep 2, 2015 10:59 PM
dibella989
Sep 1, 2015 04:12 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
