code 43 how do u fix this?
Old Feb 12, 2002 | 04:37 AM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
43. Low voltage at electronic spark timing circuit
what is this in english? it really only happens if i dont let the car warm up for 5 mins. i have an all new ignition system with an MSD 6AL box, new distributor, wires ect.. the whole 9 yards. what can be causing this? also how much of a problem is this? should this get fixed before i add a 200 shot or is this nothing i need to worry about?
Old Feb 12, 2002 | 10:26 AM
mtccl's Avatar
From the book of knowledge: "Check the voltage at the ECM A-B connector terminal B-7; it should be 6 volts unless the system is experiencing detonation. Check for a loose connection. Replace the ESC sensor and/or module." Check for a loose connection at the Throttle Position Sensor also. Good Luck!!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
BumpaD82
Feb 26, 2016 02:57 PM
64Chief
Sep 12, 2015 08:05 AM
