2 questions for electric fan wiring! please help!!
Old Feb 14, 2002 | 09:40 PM
stevver84Z's Avatar
Car: 1990 Iroc Hardtop
i have two questions
1.... there was a wiring diagram for electric fans going around i bought a painless wiring kit for my fan but i want to wire in a manual switch, how do i do it??
2....the Painless kit comes with a temp sensor....but i was wondering if i can wire it in with the one i already have on my water neck. how do i do this????
Old Feb 15, 2002 | 10:03 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Just splice a toggle switch inline on either the power wire or ground to the relay to manually control it.
The temp sensor in your thermo. housing (LG4) is for the ECM
Old Feb 15, 2002 | 05:30 PM
stevver84Z's Avatar
i am wondering if there is a way to tap into that sensor to controlmy fan
Old Feb 15, 2002 | 08:17 PM
deadbird's Avatar
Engine: TPI 305/ v6
Yea, make some sort of circuit that switches a relay based on resistance.
Jet has made a fan switch that is a much simpler solution that worrying about using the ECM sensor.
Old Feb 15, 2002 | 08:34 PM
stevver84Z's Avatar
my car never had an electric fan im adding one in and using the painless wiring relay, im just wondering about using the existing temp sensor for the painless system
Old Feb 15, 2002 | 10:21 PM
deadbird's Avatar
Engine: TPI 305/ v6
I realize what you're saying. I've got an LG4 engine too in my camaro. JET (Summit p/n JET-60600) makes a switch that screws into the passenger side head between the 5/7 exhaust ports(which I don't think has squat in it on an LG4.. never looked at mine).
At a predetermined temp (200°) the switch will ground to the block. If this is connected to a fan relay, it will cause the relay to switch on (given it has +12v on it) making your fan come on. At a 2nd temp (185°) the switch will unground kicking your fan off.
It's about the simplest way to easily add a temp controlled fan to a vehicle that never had an elec fan
In the diagram(wires are OEM color), the ECM controlled gnd would be replaced by the JET fan switch.
If you're not tapping main power from the fusable link off the battery, you'll want to add an inline 20a fuse.
You're better off forgetting about the ECM sensor as tempting as it seems
From what I see (actually seeing it now), the painless kit seems to be exactly as I just described. Other than that, I don't what else to tell you.
Old Feb 16, 2002 | 11:39 AM
stevver84Z's Avatar
ok thats what i was wondering, thanks allot you've been most helpfull!!!
eightsixseven
Dec 16, 2024 01:50 PM
MustangBeater20
Oct 29, 2022 09:20 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
redmaroz
Aug 16, 2015 11:40 PM
