Turn signal
Old Feb 18, 2002 | 06:50 PM
MD83Z's Avatar
Turn signal
Turn signal relay clicks (in dash ) but no indicator (in dash ) or lights on the car work. The stalk handle is wiggly. The right side
works fine.
Old Feb 18, 2002 | 07:30 PM
MD83Z's Avatar
OK, archives say one bulb on one side leaves all the lights on that side out.
Old Feb 21, 2002 | 11:09 PM
2vmodular's Avatar
i'm diagnosing turn signal problem too. Front left turn signal does not illuminate, back turnsignal remains on continously when left turn signal switch enaged. Turn on parking lights and left turn signal indicator on dash stays on continously.
after looking at schematics, it appears as though there is a problem with the ground behind the left headlight. will see for sure tomorrow.
Old Feb 22, 2002 | 01:19 PM
MD83Z's Avatar
Wire to the front marker light was grounding to frame. This blew fuses for the 4-way flasher and allowed the right turn signal to work fine. I would rather replace just about any water pump,belt,hose,radiator etc. than chase an electrical problem. I removed rear taillights and was about to pull the steering wheel before discovering the frayed wire up front (I guess its a bad location to keep the oil fill funnel ) . My turn signal lever will fall apart sometime, however, it seemes loose.
Old Feb 22, 2002 | 05:12 PM
2vmodular's Avatar
glad you found your problem.
the left front light headlight/turn signal wiring under the hood is troublesome because the wiring harness runs very close to the battery.
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
