Permantly ground A/C Fans??
Its probebly very east to do, but I have absolutly no real electrical expertise. If someone could just let me know how to do it really easily that be great. Thanks
if your talking about the radiator fan I would advise against it, these motors like to run on the warm side. but, if you really want to do it just disconnect the fan switch wire (passenger side of block between no. 6 and 8 spark plugs) and connect it to a good ground. the fan will then run whenever the key is on.
why do you want to do this anyway ???
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
W/o some type of external self switching device or reprogramming your PROM (if the fan is controlled as such), yes, it's called a toggle switch. This will allow you to turn the fan on whenever you fancy. Other than the above statement (b 4 yours), and what you already know about the JET fan switches, that's it.
FormulasOnly
Sep 10, 2015 09:07 PM
