Checking Relays
Old Feb 23, 2002 | 10:17 PM
cac91's Avatar
Checking Relays
Does anyone know how to check relays to see if they still function right? I have one in question and have tested the continuity on every combination of spades with the relay both "open" and "closed" and the results made sense but it doesn't work (at least that is what I'm coming to). Is there a sure fire method to check them out? My searches have been fruitless.
Old Feb 24, 2002 | 02:02 PM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
First of all, which relay(s) is in question? I check relays a similar way. I energize the relay by connecting it to a 12v power supply (make sure you're connecting the right prongs) and test the resistance across it, both when its energized and not. If the relay checks out by this method, its fine. You should take your DMM and check the electrical connections to the relay as well, and make sure there's 12 v going to the relay when its suppose to be on, and make sure there is continuity in the switched circuit as well.
Old Feb 24, 2002 | 06:56 PM
cac91's Avatar
Thanks for the help. Also, it isn't a relay out of a third gen, I just figured I'd ask because it applies to any relay.
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
Papaginos
Sep 27, 2015 03:29 PM
Fox118
Sep 1, 2015 04:07 PM
Bert87
Aug 23, 2015 03:50 PM
