Service Engine Soon light on
Old Feb 25, 2002 | 02:58 PM
Mooose's Avatar
I just bought an 89 Firebird Formula 350. On the drive home I "punched it" on the entrance ramp to the freeway and the "check engine light" came on. It stayed on for about 2-3 minutes and went out. After a couple of hours I started the car again and the light came on again for a few minutes and went out. There doesn't appear to be anything wrong with the car. Ideas?
thanks
Old Feb 25, 2002 | 08:00 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
mine does that every once in a while..........i dont worry about it too much ive done alot of modifications.....my guess is it doesnt like my downstream heated o2 sensor
Old Feb 26, 2002 | 06:11 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Even if momentarily lit the MIL light it probably stored a code. Use the jumper technique to retrieve the code. You will probably get an O2 code, 32 I think(you can get code charts on this site). You probably have a lazy O2 sensor. They have to stay around 5-6 hundred degrees to function properly. Is is fairly common when they get old to do this, or it might be contaminated. You will most likely be OK to run like this, however if it gets worse I would try to replace it. Your air-fuel mix is largely controlled from info from the O2 sensor. Danno, 89 IROC 5.7
Old Feb 28, 2002 | 02:45 PM
mtccl's Avatar
If not the 02 sensor code, check for vacuum leak. Make sure all the EGR ports are hooked up also.
Vintageracer
Jan 10, 2020 05:33 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
apie2546
Aug 10, 2015 05:43 PM
Omega
Aug 10, 2015 12:46 PM
