Need Help With Heater Fan Problem!!!
Old Mar 5, 2002 | 11:49 AM
EFF26's Avatar
Car: 1991 firebird
Engine: lo3 305 TBI
I HAVE A 91 FIREBID AND FOR SOME REASON WHEN I TUR ON THE DEFROST OR THE AIR COND. THEFANDOES NOT ALWAYS COME ON . BUT IF I LEAVE IT ON WHILE DRIVING DOWN THE ROAD IT WILL COME ON.?????
THANKS RADY EFFLER
Old Mar 8, 2002 | 03:23 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Sounds like the fan motor may be at fault. Check the voltage at the motor when the motor is exhibiting the problem with the fan on high & the engine running. If the voltage is near 13 volts, replace the motor. If the voltage is less than 12 volts, it may be the blower high speed relay, or the fusible link power feed from the large lug on the starter to the relay.
Old Mar 16, 2002 | 09:30 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
would that feed wire from the starter happen to be the purple wires at the relay plug ? why are there two ? howcome mine are both dead and only ther red and orange are hot ? and the black and tan that tie together there are dead and not grounded ?
hmmm thanks for anything at all @!
Old Mar 18, 2002 | 09:46 AM
The purlple wire @ the starter is from the ign stitch & is hot only when in the start position. One of the red wires from the large lug on the starter feeds the blower high speed relay. Check out the schematics at http://www.geocities.com/vtcamaro/Wire-Diagrams.html
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
krisner89
Oct 10, 2015 06:03 AM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 22, 2015 05:36 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
