stock 84 computer 305,to non comp 350,please help
Old Mar 12, 2002 | 02:13 PM
84,86,88Z28's Avatar
hi,im in the middle of a 305 computer to a 350 non computer swap,i took all the smog stuff off,and have headers with a t-5.now i have a few problems,is there a adapter for my sensors to fit into my 350?the one that goes into the heads wont fit,the hole is to big in the 350,also,i dont even have place for the one down by the oil pan,and cant get the block things out of them,can i put these sensors anywhere else?am i going to need a new distributor?thanks for all your help.
Old Mar 13, 2002 | 01:56 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
If the cylinder head sensor is on the driver's side, it's for the temp gauge - the head should have a standard pipe thread in that hole, so a standard NPT pipe bushing my do the trick. The sensor near the pan sounds like the knock sensor - if you leave it disconnected, the only result should be that the knock detection portion of the system will not function. The distributor should work with the 350.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro71633
Sep 1, 2015 10:24 AM
NinjaNife
Aug 23, 2015 11:49 AM
st.evel07
Aug 13, 2015 06:15 PM
Thirim
Aug 9, 2015 06:19 PM
