Attention Berlinetta Owners.....
Old Mar 12, 2002 | 05:37 PM
GregN's Avatar
For those with interior lighting problems where you turn on the headlights and the dash goes dark, I'm attempting to find the solution to the problem. I'm very close and have isolated it down to one discrete electronic component inside the lighting module. I'm in the process of finding a suitable replacement. Stay tuned for more. I'll try to post pics too.
Old Mar 13, 2002 | 01:48 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
That would most likely be a problem with the dimmer potentiometer on the LH pod, which controls the incandescent cluster illumination and flourescent tube brightness through the light control module, which is located under the passenger side dash. You may want to try contact cleaner to remove debris from the resistive surface on the pod PC board that the pot wiper contacts, and make sure that the PC board is secured to the pod front panel, as the pot wiper to PC board contact pressure relies on the board being securly fastened to the pod front panel.
Old Mar 13, 2002 | 02:35 PM
GregN's Avatar
Tim,
Already done. Checked resistance too - nice, smooth ramp from 4.8 ohms up to about "I can't remember" kilohms.
It's definitely the light module.
Lbibb
May 5, 2016 12:00 AM
Linson
Oct 1, 2015 09:50 PM
drumstixer
Sep 29, 2015 03:02 PM
rusty vango
Sep 29, 2015 02:44 PM
manifoldsrme
Sep 17, 2015 11:40 PM
