loss of power 86 camaro
Old Mar 19, 2002 | 10:59 PM
zero_mcm's Avatar
I put a crate motor in,about 8 months ago,and had timing set and fuel system cleaned. Ran fine, after about 6 months. It had a loss of power again.replace fuel injectors,tps, and did tune-up. And still no power. Then replace Ecm, I had power after i did that. Then I replaced the mass air flow,the next day, because the engine light stayed on since i replaced motor. When I put The MAF on, and reconnected battery cable. the car was jerking in every gear. then a few mins later, I had loss of power again. Could this be a result in the wiring. Or suggestion what else i should check.
86 camaro. mp fuel injected
2.8L
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Sep 17, 2020 08:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Bradsaundry
Aug 12, 2015 12:34 AM
