Key cylinder prob;em
Old Mar 23, 2002 | 10:34 AM
BLUEIROC5.7's Avatar
Hey all i am trying to replace my key cylinder. I have got the wheel off. I have the tool to remove the lock plate but it is not working. Is there something that i need to do special.
Old Mar 24, 2002 | 08:34 PM
TopForm's Avatar
There is a small steel ring you need get out of the groove once you depress the lock plate, then it should come off as you release the pressure of the tool. Take out the spring and T/S cancelling cam. There is one long bolt with a Torx head that holds the cylinder in place. Once removed the cylinder will pop right out. Very easy.
Brian
Old Mar 25, 2002 | 05:43 PM
Hey thanks man i got it all done
Old Mar 26, 2002 | 01:08 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
yeaa it's fixed, with a little of my magic
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
db057
Apr 28, 2019 07:45 AM
85cmroz28
Oct 4, 2015 09:44 PM
sahlomonic
Sep 20, 2015 07:15 PM
Gunsbee
Sep 7, 2015 07:10 PM
