Help! Dash lights out! Cant see speedo at night!
Old Mar 27, 2002 | 01:23 PM
305IrocZ28's Avatar
Car: 1990 IROC-Z
Transmission: 700-R4
Yeah, I've been having a lot of problems with lights going out on me. First it started with my speedometer needle light going out, which was usually re-startable with a firm fist to the top of the dash. however, now all the lights on the left side of my gauge cluster (speedo, oil pressure, fuel) are out. Is this a fuse problem, or am I just going to have to pull the cluster out and replace the lights? If anyone has done this before, your help would be appreciated.
Old Mar 27, 2002 | 01:38 PM
Berlinetta's Avatar
sounds like a loose wire and maybe bad bulbs. The pounding the fist bit tells us its a loose wire. I pity you if you have to take the dash apart
Jorlain
Aug 24, 2022 05:11 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
