Any Performance Chip suggestions?
Old Apr 12, 2002 | 07:28 PM
Camaro68Vette63's Avatar
Car: 1992 Z-28 Camaro
Engine: LB9 305 TPI
Any Performance Chip suggestions? Personally I was going for a hypertech. If so please tell me why it is any better thanks.
Old Apr 13, 2002 | 07:13 AM
Z28DJP1987's Avatar
Hypertech are Junk, for the best try www.fastchip.com.
Old Apr 15, 2002 | 06:44 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Unless you race I personally feel they are a waste of money. I tried a couple of different ones an noticed nothing different. The stock PROM has good driveability characteristics and also enables you to run regular fuel. If you are looking at tenth's then it is probably worth it, but for around town I doubt that the money spent will be noticeable. And I concur, among the people I know who do race the fastchip is well liked.
Old May 1, 2002 | 07:49 AM
gtabadboy's Avatar
Only advice I can give is DO NOT get a hypertech. I sent mine back 4 times and in the end had to return it all together. I lost 100 dollars for the tech fee.
Old May 4, 2002 | 09:27 PM
rsc350's Avatar
Car: 92 Camaro RS
Axle/Gears: 3.73 Truetrac
spend the $200 and buy your own burning equipment. Easiest and you can fix anthing oyu want that way
Old May 9, 2002 | 04:08 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
If yo're not burning your own chips (admittedly, the best method) the next best thing is Ed Wright at Fastchip.com.He burned my custom chip and I had it in two days.Works great.
Plan on supplying him with a ton of info about your combo, if you want it to be right.I hear good things about his off-the-shelf chips as well.
-Rich-
Old May 10, 2002 | 07:17 AM
Z28DJP1987's Avatar
www.fastchip.com a good off the shelf and custom chip as well.
Hotrodboba400
Dec 10, 2019 07:07 PM
64goatman
Sep 9, 2015 01:09 PM
Formula_88AE
Sep 3, 2015 01:47 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
