can a relay click when getting power and still be bad?
Old Apr 13, 2002 | 07:06 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
this is not factory wiring. I have 2 relays one for each fan and they are getting juice but not putting out anything to the fans.
Fans check out ok.
Old Apr 13, 2002 | 07:41 PM
Omar's Avatar
Relays RARELY go bad...but they do.
Tell ya what...why not substitute 2 known good relays in place and see if the fans turn on? Relays are fairly inexpensive.
If purchasing some new relays are out of the question, why not apply power as if you are turning on your fans, and test to see if you have 12V coming out of 87A and/or 87 (depending on whether you are using SPDT or SPST relays). A simple test light will do the trick.
Old Apr 13, 2002 | 08:44 PM
2vmodular's Avatar
clicking you hear inside the relay case is the coil moving the contacts. the noise does not ensure that the metal parts inside will properly conduct electricity.
Old Apr 14, 2002 | 10:54 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
well it was not the relays
I don't know actually what happend. But, I ran another wire using new switch from a different source and the manual fan is working again.
Going to try to run the second fan through a temp switch sensor that will automatically start the second fan at 205.
thanks
BRoss99
Aug 10, 2025 05:08 PM
Glowsock
Jul 24, 2025 03:15 PM
89GTAOz
May 16, 2020 09:31 AM
B_Dubya
Aug 26, 2015 05:09 PM
Bert87
Aug 23, 2015 03:50 PM
