Ported AFR 195 heads for sale,ZZX cam,Rev Kit
Car: 91 Z/28
Engine: 6.3 L98
Transmission: TH350 4500 STALL
Axle/Gears: 3.73s
I have a set of ported assembled 195cc AFR aluminum heads for sale.Angle plug, 64 cc, 2.02 /1.60 valves,7/16 studs/guideplates and afr 1.45 springs .Heads have been ported nicely,smooth as a babies butt lol.Heads flowed 286 cfm @ 600.Previous owner had them done.(86IROC)on this board. These heads have approximately 200 miles on them.They are perimeter valve cover.I would like to get 1000.00 for these.Pics are on my webshots home page,link is below.
I also have A TPIS used ZZX cam for sale.
Advertised Duration 290/290
Duration @.050 239/239
Gross Lift .558/.558
Lobe Seperation 112
This cam got my 383 running 11.0s-11.2s and mph usually in the 120-123 range.Ive ran this cam is my car for about 5 years.Cam has some slight wear. Asking 100.00.Pic is also on my webshots page below.
Also have a AFR hydra Rev kit to sell.No pics but can if you need them.Approx 200 miles on the kit.Almost new.Asking 150.00.
for looking!
Webshots - Images of 91 Z
Lobe Seperation 112
for looking!Webshots - Images of 91 Z
Car: 1991 Z-28
Engine: 383 / TPIS MINI RAM
Transmission: 700-R4
Axle/Gears: MOSER 9IN 3.89
HI 11SEC, The AFR hydrarev kit, will that work with roller tappets, I have AFR 195 HEADS also. Also is that 200miles a 1/4 Mile at a time.....lol.Big difference you know...
Car: 91 Z/28
Engine: 6.3 L98
Axle/Gears: 3.73s
Pms sent, Zeeyaa.These heads are from the motor of old member 86IROC.The car was never completed.He purchased a ls1 car and lost interest.He drove the car around in his neighborhood but never got all the bugs worked out like brakes and stuff,then the ls1 came along so he parted out the 86.So 200 miles is approximated and possibly less.Yes the Rev kit is for hydraulic rollers.Unless you swapped to a older pre 86 block the rev kit will work for you. Thanks
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
So the Rev kit is for factory roller cams not for retro-fit roller cams...correct?
Car: 91 Z/28
Engine: 6.3 L98
Axle/Gears: 3.73s
Car: 91 Z/28
Engine: 6.3 L98
Axle/Gears: 3.73s
Originally Posted by Justin89Formy
I never got my PM
re-sent ya a pm Last edited by 11SEC91Z; Apr 8, 2006 at 11:53 AM.
Transmission: t-5
Car: 91 Z/28
Engine: 6.3 L98
Axle/Gears: 3.73s
Originally Posted by FRISCO_RIDER69
Hey whats up bro... do you still have the heads for sale. what about the miniram? is that for sale too and if it is, how much are you asking for.
Transmission: t-5
Car: 1988 Irocz
Engine: 355 Stealthram
Transmission: 5speed
Axle/Gears: Stock 10bolt 3.73 posi
Are the heads still for sale, if so are the intake ports matched to a particular gaskets such as 1205 or 1206. Iam looking into a stealthram but heard it wont seal to a 1206 gasket. What specs are the valve springs? Thanks Chad
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
I *just* got my check back from the postal service today. its been what, a month now? And you're only 2 hours away. Should have just drove out to get it lol
1988iroc350tpi
Aug 14, 2015 07:52 PM
