nice roller cam
Old May 12, 2006 | 02:04 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
nice roller cam
OPEN TO OFFERS.. THIS IS A BRAND NEW CAM.. SUMMIT SELLS IT FOR 269.99 ... NEED TO SEL IT ... PM OR EMAIL ME OFFERS...
Part Number: 104225 Grind Number: POWERMAX 2031 (FORMERLY COM
Engine Identification:
Start Yr. End Yr. Make Cyl Description
1987 1989 CHEVROLET 8 FOR MID AND UPPER RPM PERFORMANCE IN 88-89 305 ENGINES W/5-SPEED AND 3.45 OR NUMERICALLY HIGHER REAR GEAR RATIOS. ADJ. FUEL PRESSURE REGULATOR (99470-1) IS RECOMMENDED FOR MAX. PERFORMANCE (50 STATE LEGAL FOR LISTED APPS, C.A.R.B. E.O. D-225-22) BASIC RPM 1500-5000
Engine Size Configuration
305 C.I. V
Valve Setting: Intake .000 Exhaust .000 HOT
Lift: Intake @Cam 292 @Valve 438 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 301 @Valve 452
Rocker Arm Ratio 1.50
Cam Timing: -- @---
Lift: Opens Closes ADV Duration
Intake --- --- 264 °
Exhaust --- --- 270 °
Spring Requirements: Triple Dual Outer Inner
Part Number 96802
Loads Closed 107 LBS @ 1.800 or 1 13/16
Open 271 LBS @ 1.370
Recommended RPM range with matching components
Minimum RPM 1400
Maximum RPM 5400
Valve Float 6000
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake (3)ATDC 31 ABDC 107 208 °
Exhaust 44 BBDC (10)BTDC 117 214 °
Old Sep 11, 2008 | 09:12 PM
adm030's Avatar
Car: 92 camaro rs
Engine: lo3 305 tbi
Axle/Gears: 2.73 , 3.42 soon
Re: nice roller cam
do you still have this if so how much shipped to minden,la 71055
Old Sep 11, 2008 | 09:27 PM
bbtaz97's Avatar
Car: 91 RS
Re: nice roller cam
check your PMs
Old Sep 11, 2008 | 09:44 PM
bbtaz97's Avatar
Car: 91 RS
Re: nice roller cam
if anyone else is intrested in this as well i have it ready to ship still.
junkcltr
Aug 2, 2019 11:12 PM
gixxer92
Sep 1, 2015 04:32 PM
camaro71633
Sep 1, 2015 10:24 AM
anesthes
Aug 8, 2015 09:37 PM
