S/R Torquer 305 Heads, Compucam 2031, Edelbrock TPI High Flo intake for sale
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
S/R Torquer 305 Heads, Compucam 2031 for sale
For Sale: Sold as a package - World Products S/R Torquer 305 heads (pre-86 intake pattern perimeter bolt valve cover style) and CompuCam 2031 with a few thousand miles on them. Head specs 170cc intake port, 1.94 int valve 1.50 exh valve. Mild pocket, intake, and combustion chamber porting and polishing has been done. Includes matching Crane Cams valve springs already installed for the Compucam 2031. Items brand new are around $1000.00 but only asking $450.00 not including shipping. Edelbrock intake no longer for sale...
Cam specs are as follows:
Part Number: 104225 Grind Number: POWERMAX 2031 (FORMERLY COMPUCAM 2031)
Valve Setting: Intake .000 Exhaust .000 HOT
Lift: Intake @Cam 292 @Valve 438 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 301 @Valve 452
Rocker Arm Ratio 1.50
Cam Timing: -- @---
Lift: Opens Closes ADV Duration
Intake --- --- 264 °
Exhaust --- --- 270 °
Spring Requirements: Triple Dual Outer Inner
Part Number 96802
Loads Closed 107 LBS @ 1.800 or 1 13/16
Open 271 LBS @ 1.370
Recommended RPM range with matching components
Minimum RPM 1400
Maximum RPM 5400
Valve Float 6000
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake (3)ATDC 31 ABDC 107 208 °
Exhaust 44 BBDC (10)BTDC 117 214 °
Remarks:
AN ADJUSTABLE FUEL PRESSURE REGULATOR ( CRANE P/N 99470-1 ) IS REQUIRED FOR USE WITH THIS CAMSHAFT.
Cam Timing: -- @---
Part Number 96802
Minimum RPM 1400
Maximum RPM 5400
Valve Float 6000
Remarks:
86IROC112
Aug 17, 2015 02:00 PM
