TPIS MiniRam '91 Vette Heads 355 Short Block
Been awhile since I have been able to work on the car, so I am parting out my 87 GTA. Right now I have:
TPIS Miniram gasket matched to FP 1205. Includes Fuel rails, SVO 30 lb injectors, 58mm BBK Throttle body that will come with TPS and IAC
The top was polished at one time, but has been sitting so there is some pitting. I polished a small area with good results, so it shouldnt be too much work to get it new looking again. $1200 You pay actual shipping.
D port Aluminum Heads also gasket matched to FP 1205. These will need new springs and seals. No damage, just used cheapie springs that did not handle what it was rated for. Includes the corvette valve covers. $450 You pay actual shipping.
I also have the 355 short block that I will pull in the next few weeks. I have to get the build sheet for the specs though. 4 bolt main, forged pistons, LPE 219 cam, thats all I can remember right now...Let me know if you are interested, its clean and has about 4K miles on it. I will not ship this, so local pick-up a must. Im on Long Island, NY
You can PM me here, or email me at i987gta@aol.com I plan to put this stuff up for auction by the weekend, let me know if anyone can use these things before then. Thanks
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
I know you want a pkg deal, but if you'll consider the miniram minus the tb and injectors lemme know. I have 55lb/ inj. and a slightly smaller tb already only reason I'd ask to seperate....
Thanx
PETE
Thanx
PETE
Update, and additions for sale!!
Just to update the sale of miniram and heads are sold. I havent pulled out the engine yet, but here are the specs. i am looking for a pick up here, so no shipping. I am in Smithtown, NY Long Island 11787 if that helps you. I also have a GTA limited slip 9 bolt rear w/ 3.23's and full rear disc setup A bunch of other stuff out of my 87 GTA and full tan/camel interior (leather, fronts need to be recovered) and plastics from my 89 GTA. let me know if there is any interest, and make some offers. Thanks, Joe
355 SBC short block specs:
'94 block 350 .30 over 4 bolt roller with a 1 piece seal.
-.10 cut crank
-clevite 77 bearings
-melling hi pressure pump
-shot peened rods w/ARP rod bolts
-4 bolt main stud kit
-LPE cam 219 I/E @ .50 .525 in/lft I/E with 1.5 rockers .560 in/lft I/E
w/
1.6 rockers 112 lobe seperation
-TRW forged pistons
-Moly rings
-Crane Dual Roller Chain
-Fully balanced
Not even 4k miles on this, never sprayed, ran very strong, but I couldnt pass emissions with the miniram in my state, no egr! Im Taking Offers! Thanks
-.10 cut crank
w/
-TRW forged pistons
-Moly rings
-Fully balanced
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
I'd be interested in the corvette valve covers...
Sanjay
Aug 12, 2015 03:41 PM
