High performance comp camshaft!
Old Jul 2, 2006 | 01:05 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
hydraulic roller, 230/236 duration @ .050"
.510/.520 @ .050" duration
110 LSA.
good for shifting around 5700-6000 rpm.
sounds awesome at idle, does work with stock ecm. never used
will throw in some springs for free if u want them they are beehive 1.55" not sure on brand. about 1k miles on the springs.
200+shipping.
Old Jul 2, 2006 | 02:56 PM
fire89irocz's Avatar
Car: 89 Chevrolet Camaro Iroc-Z
Engine: 350 5.7L w/ LT1 intake
Transmission: World Class T5
Cam and springs
hi, I am very interested in the cam your selling. I was wondering what the part number was to the cam. If the springs are the ones ment to work with the cam I will definitly take them too. If it is the one I want I will send you money either monday or tuesday. Please send pics of the cam and springs to fire73087@yahoo.com. Thanks.
-Jared
Old Jul 2, 2006 | 06:07 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
like i said, cam is NEW and springs have about 1k miles on them, they still look new.
Attached Thumbnails High performance comp camshaft!-comp1.jpg   High performance comp camshaft!-comp2.jpg   High performance comp camshaft!-comp3.jpg
Old Jul 2, 2006 | 06:09 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
cam part # is CCA-12-432-8
I never used it because I bought it but didnt fit in my stroker application so instead of sending it back to summit cuz im lazy, i bought the same cam in a small base circle version and that fits in my 383. so anyways here you go. and u can have these springs that fit the cam as well. part number 987-16.
let me know your zip code and ill get you shipping quote.
Old Jul 4, 2006 | 01:16 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Anyone?
Old Jul 7, 2006 | 02:31 PM
chevyengr's Avatar
Car: 1990 IROC-Z 350Stealthram 11.61@120
Engine: 350 Stock Bore&Stroke
Transmission: 700R4 Auto/Vigilante 2600
Axle/Gears: 3.42 Stock 10 bolt
Springs Q?
Are you willing to sell the srpings by themselves? If so, how much shipped to 78562?
Let me know!
Old Jul 7, 2006 | 03:42 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
ill sell the springs for 200 shipped and ill throw in a cam for free
Old Jul 8, 2006 | 09:17 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
if it were a retrofit id be all over it
Old Jul 8, 2006 | 01:21 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
why does it have to be retrofit? all you need then is a new timing set.
Old Jul 14, 2006 | 03:36 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
still up for grabs!
Old Jul 14, 2006 | 10:52 PM
SlowCamaro88SC's Avatar
will it work w/ a '84 based 350?
planning on using my TPI on this new 350, and it needs a cam.
Old Jul 15, 2006 | 02:11 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i think 84 is the last year of the non roller blocks as far as thirdgens go. you would need the roller lifters with the bridge between them since the block is not provisioned to keep them aligned. it is doable. just the lifters could be pricey. (aprox 250 dollars for the set)
Old Jul 15, 2006 | 04:37 AM
my motor is a reman actually, a Jasper, pretty sure it's full roller
I'll check tomorrow.
Old Jul 15, 2006 | 08:00 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
roller blocks werent o/e till 1987
my oe retrofit lifters werent 250 dollars, almost 100 more than that
Old Jul 17, 2006 | 05:33 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
You've got a PM.
Old Jul 20, 2006 | 05:32 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
TTT
Old Jul 22, 2006 | 12:49 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
ttt
Old Jul 22, 2006 | 08:39 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
ttt
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
Stryker412
Sep 7, 2015 09:11 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
