A bunch of TPI parts! EVERYTHING and 2x58 accel tb
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
I have everything you need for a tpi.
Manifold with tstat and housing
Runners NO DENTS!
Plenum very clean
Distributor cover
Accel billet 2x58 throttle body (will include reciept from summit, costs 550 there now) with iac motor and tps sensor etc.
Feul rails with regulator
19 lb injectors
MAF sensor
All other sensors
Maybe wiring harness
Ecm with tpiparts.net chip (bought chip a week ago) for 350 maf tpi with auto, cold start, and no vats
K&N air filters
Y shaped intake piece
Intake piece right before TB
Air filter baffle thingie where you put the filters
And anything else you can think of. Just start throwing me prices...wont have them off the car till the weekend. All is pretty clean and fully functional. My distributor got all screwed up, so i switched to an old one, and now it wont work with the computer...and im just saying screw it and going with a carb setup. so trades maybe? thanks a lot.
Runners NO DENTS!
Plenum very clean
Distributor cover
19 lb injectors
MAF sensor
All other sensors
K&N air filters
can you give me a list of each part you would like and i can make sure i have all of it...and also i can tell you which pieces i do not have.
Undented runners: 50 plus ship
Plenum opened for 2x58 tb: 50 plus ship
Accel billet throttle body 550 at summit: 250 plus ship
Base for pre 87 heads: 50 plus ship
Bosch mass air flow sensor: 75 plus ship
Feul rails with regulator: 50 plus ship
Ecm with brand new chip with reciept, less than 2 weeks old: 125 plus ship
Im not sure about ripping out the harness yet, I might get to that later. And i gotta look up what injectors go for some time. Let me know if theres anything I am forgetting.
Oh yea, the distributor cover thing. Anyone need one of those?
bump, i thought this would be a little easier.
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
this is from an 86 305 tpi camaro actually. so it will work.
how much do those dist covers go for?? hm, maybe 15 bucks? i dno if theyre hard to find or anything.
list updated! ttt
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
How much for the EGR solenoid with plumbing? Can you get me pictures of the part? duts87ss@yahoo.com
Also, I have a carb and dist that I pulled off my Monte to go TPI. Both have low miles. Theres also the Weiand 8004 intake that I can clean up for you.
i only have swap parts left to get..like a feul pressure regulator, and some lines, and stuff like that. send me a picture of what part youre talkin about cause im not exactly sure what it is. then ill grab some pics and tell me what you think of the part.
Here's the solenoid:
Here's what the lines coming from the solenoid look like:
yea i got that. how much is it worth to you?
ttt, still have many wires and sensors, k&n filters, y piece intake, air filter baffles, computer, and prom.
ok i think the sale fell through. everything except for the MAF is for sale once again.
list edited again.
list edited again.
i already started hacking at it. just too much work to get it out, plus i still need some of the electronics.
Do you still have the runners? If so, I will take them......
Please email me at
sbeal@sirinet.net
Thank you,
Woody
Please email me at
sbeal@sirinet.net
Thank you,
Woody
sent email but no response. everything cept the maf is still for sale.
forgot to put a shim back in when we rebuilt it. but all the parts in it are good. cap, coil, module, pickup, etc.
bump
BUMP
aargh
Car: 1991 trans am
Engine: 5.0l TPI
Transmission: 700 R4 Auto
Axle/Gears: Don't know... DO U!
still got injectors? if so pics and prices.... i need a set bad but only if they all ohm out at around 16
i cant guarentee they all ohm out at 16 cause i dont have any way of doing that. the car was running fine before, i just wanted to go carb. i can sell you them without that guarentee though, and ill try to grab some pics tomorrow.
Re: A bunch of TPI parts! EVERYTHING and 2x58 accel tb
Hello,
I bought an 86 iroc I was wondering if you still had the egr and lines, I know the posting is very old but thought I would give it a shot.
Thanks,
Jon
Thanks,
Jon
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Car: 1971 Camaro
Engine: 427
Probably better off posting in the wanted section.
The OP has not even been on the site in a year.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Are you looking for the hard line piece from the solenoid to the tb and the solenoid to the egr valve ? If that's the case I believe I still have one and the egr solenoid in good working condition.
The pictures you posted on post 16 is what I need except the solenoid mounting bracket looks a little different then mine, if you could send me pics to verify with price thanks
email chinitojon@yahoo.com
Engine: Lb9
Transmission: M20
no pic in 16, post17 has a 87-92 solenoid and vac line. Joined: Dec 2004
Engine: Lb9
Transmission: M20
I will send you a email later today, for sure Ai have a good solenoid and bracket. I will have to search for the line
Engine: Lb9
Transmission: M20
Sorry for the delay, I have company over tonight send me a pm and I will answer later on tonight not sure when yet. These were off my 85 pulled off at 103k and stored since 95.
Engine: Lb9
Transmission: M20
I hope I'm not jacking a dead thread. The plastic egr tubing is snapped off were it
T's off to goto the ccp.
1992rs/ss
Jan 31, 2025 05:10 PM
Sanjay
Aug 12, 2015 03:41 PM
