Wilwood Proportioning Valve
Old Jul 25, 2006 | 10:28 AM
91NiteRida''s Avatar
Car: 1991 Camaro
I have a brand new,never used,still in package Wilwood Proportioning valve for sale. I was going to use it on my camaro but sold my camaro.$30 dollars shipped.email me at js2ndiinone@aol.com for info. Paypal preferred
Old Jul 25, 2006 | 12:05 PM
Millerboy's Avatar
Car: 1984 camaro z28
Engine: 305, soon to be a 350
What does the proportioning valve do. I am very interested. I think mine is going bad because the front driver break wears out before the front passanger. SO I am interested in what it does. COnsider me first in line.
Old Jul 25, 2006 | 12:26 PM
Car: 1991 Camaro
most guys use the proportioning valve when doing a drum to disc brake swap in the rear
Old Jul 25, 2006 | 12:28 PM
Jeremy_84_F41's Avatar
Car: 1991 Formula L98
Axle/Gears: 3.73:1
It won't affect bias from left to right, typically these adjustable valves are installed to control the amount of pressure going to the rear brakes. You most likely have other brake issues.
Old Jul 25, 2006 | 12:43 PM
luke4907's Avatar
Car: '89 Trans Am GTA
Engine: TPI350
Axle/Gears: BW 3.27s
What you are describing is somewhat common as long as the difference isn't drastic. If you are experiencing pulling to the left or right as you brake then I'd suspect air in the brake lines or bad calipers.
91NiteRida', sorry bout that I just wanted to offer my help to Millerboy. This is the adjustable Wilwood unit, correct? If so, I'll take it. Let me know, thanks.
Old Jul 25, 2006 | 12:47 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
not to hijack the thread but..
replace your flex lines.. they're ~6 to 12 each... 3 lines. one for each front wheel, and one for the rear axle.
take off your brake calipers and clean the slider pins. then re-assemble with lube.
thoes two things will probly fix your problem right there.
back on topic..... i have this same wilwood prop valve... works great. id reccomend it to everyone.
Old Jul 25, 2006 | 01:04 PM
Millerboy's Avatar
Ok, I won't need it then. I have been thinking it was the valve or the caliper. It pulls to the left and wears out almost twice as fast.
Old Jul 25, 2006 | 01:48 PM
litemanmiller's Avatar
Ill take it got an 89 rs I want to convert to disc. Let me know what shipping is to 53714.
TJ
Old Jul 25, 2006 | 02:18 PM
Car: 1991 Camaro
30 dollars shipped
Old Jul 25, 2006 | 02:37 PM
luke4907's Avatar
Engine: TPI350
Originally Posted by 91NiteRida'
30 dollars shipped
I've posted on here already and e-mailed you. Once you give me the word that it's the adjustable proportioning valve and I know about it you'll have $30 in your paypal. Please let me know if this is the adjustable unit or give me a part number if you have one. Thanks.
Old Jul 25, 2006 | 02:41 PM
Car: 1991 Camaro
here is the part # 260-8419
Old Jul 25, 2006 | 02:56 PM
luke4907's Avatar
Engine: TPI350
Payment sent to aol e-mail address listed above.
Old Jul 29, 2006 | 02:11 PM
luke4907's Avatar
Engine: TPI350
Received the part today. Fast shipping via priority mail (coast to coast in a few days). Would buy from this guy again. Thanks again!
Old Jul 29, 2006 | 02:15 PM
Car: 1991 Camaro
Glad you recieved it!!! Thanks for the business!!!
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
sleprock
Sep 24, 2015 04:33 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
