355 with AFR heads
355 with AFR heads
Fresh 355 with one piece rear main, cast crank, polished and balanced stock rods with ARP bolts, TRW forged pistons with .100 domes. motor should be 9.8 compression with the AFR heads, Weiand Team G intake, new 76cc AFR 210 aluminum CNC ported heads with titanium retainers, new comp Pro Magnum hydraulic roller lifters and rockers, Comp cams hydraulic roller cam 245/254 duration, .540 lift on a 114.
$2800 intake to pan
$2800 intake to pan
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
I'd be interested in the heads if you part it out.. then again they might be too big for my application
Car: 87 IROC
Engine: 5.3L
Transmission: Jerico
Axle/Gears: Aluminum 8.6 w/ T2R
evilstuie
Jan 9, 2020 08:29 PM
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
