AFR 195 headed,fully forged 355
Old Sep 21, 2006 | 02:31 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
'82 350 4 Bolt bored .030" over
*secured with ARP main studs #134-5601
Summit Pro Line 4340 forged steel crank and rods
*3.48 stroke/5.7" length (bushed small ends)
Manley Forged 10:1 Sportsmaster Flat Top pistons
*full floating/2 valve reliefs/forged
Speed Pro file fit plasma moly ring set # 9771.035
*file fit to .024" first & second rings
*standard tension oil rings
Clevite main,rod and cam bearings
Comp Cams Xtreme Energy 274 hydraulic flat tappet cam
*.487"/.490" lift 230/236 degrees duration at .050" lift/110 lobe sep
Comp Cams Pro Magnum steel roller rockers 1.52-3/8 stud
Comp Cams hardened pushrods
Cloyes "True" double roller timing chain #9-3100
Edelbrock #4242 2-pc Timing Cover
AFR #1036 195's 64cc street ported heads straight plug
*milled from 74 to 64 cc
*secured with ARP head studs #134-4001
AFR cast aluminum valve covers
Edelbrock Performer RPM Air Gap intake
7.25" Fluidampr SFI Harmonic Balancer w/ Tavia Timing Pointer
Moroso 6 quart pan 8.25" deep #20180 w/ Moroso HV oil pump & pickup
MSD Pro Billet #8361 distributor w/vacuum advance
ARP Engine & Accessory Fastener Kits #070-534-9601
March Pulleys serpentine conversion brackets and pulleys ($550 new)
Hooker 2210 long tubes,these are Brand New and have been modified to clear the AFR straight plug heads.Just need to be coated.
This is a complete motor from intake to oil pan.Drop it in,add carb and drive.
NO CARB.
At 3390 lbs the motor ran 13.3x @ 105 shifting at 5200rpm in 90 degree weather in my '82 z28.Alot more potential left in it.
Only selling to fund LSx swap.
Want to sell complete as listed.Please don't ask to part!
Engine was built in early 2000 and has no more than 7,500 miles on it.
I have receipts for every last piece.
$4500 for engine,March pulley setup and headers.
Old Sep 23, 2006 | 12:08 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Will part out if reasonable offers are made?
Only thing I won't sell in parts is the March pulley setup.That sells complete.
Old Sep 23, 2006 | 01:54 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Are you willing to Sell just the headers? If so could you send pics to cain@olyen.com
Old Sep 24, 2006 | 12:09 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
izcain I will send you pics tomorrow!
Now Parting!
Manley Forged 10:1 Sportsmaster Flat Top pistons #49423
*CB663H rod
*MS909H main
*SH290S cam
$1200 for short block,cam and lifters
Must be pickup or delivery only.Will not Ship
All prices that follow are with shipping!
Comp Cams Pro Magnum steel roller rockers $175
*#1301-16 (1.52 ratio-3/8 stud )
Crane Cams pushrods $50
*#11621-16 (5/16")
Cloyes "True" double roller timing chain $30
* #9-3100
Edelbrock #4242 2-pc Timing Cover $45
AFR #1036 195's 64cc street heads straight plug $1000
AFR cast aluminum valve covers $50
Edelbrock Performer RPM Air Gap intake #7501 $125
7.25" Fluidampr SFI Harmonic Balancer $200
#720101
Tavia Timing Pointer for 7.25" balancers $15
#02354
Moroso 6 quart pan 8.25" deep #20180 w/ Moroso HV oil pump & pickup $125 or $80 for just the pan
w/ Crane Cams Adjustable Vacuum Advance #99601-1 $155
Hooker 2210 long tubes,these are Brand New and have been modified to clear the AFR straight plug heads.Just need to be coated. $400
Tommy Johnson Motorsports Mini Starter #774-66256 $65
Edelbrock Long Water Pump #8811 $75
Aluminum Swivel Water Neck #sum-371101 $15
AGR Power Steering Pump #8545P $70
Hays Billet Steel 153T flywheel #10-330 $150
Centerforce DF Clutch #DF161056 $125
26 spline 10.5"
March Hi Water Flow Ratio serpentine pulleys #6380
March Power Steering pulley #624
March Water Pump Nose Cover #314
March Alternator Fan #221
March PS Bracket #20165
March Alternator Bracket #20121
$450 complete or $120 for the brackets and $350 for the pulleys
All parts have 7500 or less miles on it.Some are near brand new.Email or PM if interested.
Old Sep 25, 2006 | 08:21 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Please Disregard.No longer for sale.
gixxer92
Sep 1, 2015 04:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
