tpi setup, msd 6a, tpi oil cooler
Car: 86 Monte carlo ss
Engine: tpi l98
Msd 6a box. Has harness with cut wires on it. Came off a camaro my TPI engine came out of. It was included in the deal I made with the guy for my engine/tranny. $75
TPI oil cooler- screws on in place of the oil filter, and then oil filter screws onto it. Could be used with other small blocks. Nice shape Includes metal line. $30
I also have a corvette style TPI setup aka- fuel feed line is on opposite side. It is in AWESOME SHAPE, minus a small dent in a tpi runner. The Plenum is polished, The throttle-body is tight. Everything is clean. It includes the lower manifold, stock runners, injectors, fuel rail,EGR valve, polished plenum. If you look at it, it doesn't look like it was on a car very long. And if it was the car wasn't driven much, cause it doesn't have any corrosion on it at all. Just a little dusty. It is missing the fuel pressure regulator(diagphram) and some plenum bolts. I do have an adjustable regulator I will include, but you will still need to get the diaphram that has the frame rail connected to it. It has a spot for the 9th injector $125
Or everything for $200
Car: 93 TA, 92 GTA, 91 TA
Engine: LT1, L98
Transmission: T-56, 700R4
Axle/Gears: 3:23
Interested in the box and that intake.
you got pics?
you got pics?Thanks
Engine: tpi l98
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
toronto formula
Nov 10, 2015 06:17 AM
