Engine parts
Old Oct 11, 2006 | 08:04 PM
Fstbk272's Avatar
Car: 87 Firebird, 90 corvette, 05 F150
Engine: 5.0, 502, 5.4L
Transmission: AUto,Auto,Auto
Engine parts
72( ithink) 350 4 bolt block. 4 bolt. bored .060. decked .010. new cam bearings, new freeze plugs, . magna fluxed, cooked and cleaned.painted chevy orange looking for 500$ machine work cost me 600$
New in Box Eagle 4340 forged crank. 350 journals, 1 pc rear main seal. 3.48" stroke. PN 435334805700-450$
New in box SRP Forged alumn. pistons. 350 .030 -24cc dish. for 6" rod. bushed. -500 OBO
Fel-pro 1406 header/manifold gaskets. -10$
Mr gasket MLS gaskets. PN 3130G. .040 compressed thickness fits up to 4.060 Bore. 80$/pr. They cost 65/pc.
Comp cams 305 cam. Pm 08-305-8 -220$ OBO
Specs are:
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 1,800-5,800 RPM
Intake Duration at 050 inch Lift: 220
Exhaust Duration at 050 inch Lift: 230
Duration at 050 inch Lift: 220 int./230 exh.
Advertised Intake Duration: 276
Advertised Exhaust Duration: 290
Advertised Duration: 276 int./290 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.510 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.510 in.
Valve Lift with Factory Rocker Arm Ratio: 0.510 int./0.510 exh. lift
Lobe Separation (degrees): 114
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Comp cams Solid roller cam. Cam is "NEW" never used, never turned, never had a timing chain, or lifters or any pressure on lobes, but has been placed in a block, and has assembly lube on it. but it is still brand new. -220 OBO
570/576 lift 242/248 dur. @.050
110 LSA on 106 Centerline.
grind - CS XR280 R-10
Cam Style: Mechanical roller tappet
Basic Operating RPM Range: 2,500-6,500 RPM
Intake Duration at 050 inch Lift: 242
Exhaust Duration at 050 inch Lift: 248
Duration at 050 inch Lift: 242 int./248 exh.
Advertised Intake Duration: 280
Advertised Exhaust Duration: 286
Advertised Duration: 280 int./286 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.570 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.576 in.
Valve Lift with Factory Rocker Arm Ratio: 0.570 int./0.576 exh. lift
Lobe Separation (degrees): 110
Intake Valve Lash: 0.016 in.
Exhaust Valve Lash: 0.018 in.
Computer Controlled Compatible: No
Grind Number: CS XR280 R-10
New OE style comp cams roller lifters. PN- CCA-850-16 160$
PM me or email me for pics. hippiehead025@adelphia.net - Roger
Old Oct 12, 2006 | 07:41 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
OE roller type or retro fit?
As in does it have it have the recess on the cam nose for the factory retainer plate?
CC part #?
Old Oct 12, 2006 | 04:09 PM
Fstbk272's Avatar
CCa-12-771-8 required botton and wear plate. - Roger
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
Caspar
Jun 19, 2016 11:19 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
1nastygta
Aug 8, 2015 07:38 PM
