Spohn torque arm and custom driveshaft
Old Oct 12, 2006 | 08:11 PM
blown3rdgen's Avatar
Spohn Adj Torque Arm w/ drive shaft loop- Red with poly bushing. I have it hooked to a ford 9", but it has 2 sets of mounting bolt holes so I believe it will work with stock set-up (need to check with spohn)......250
custom 3.5" aluminum drive shaft with 1350 u joints- Set up for 700r4 to ford 9". Would need at least u joint changed IF connecting to stock rear and would need to measure length.....150
B&M console megeshifter- Works fine, but no line to indicate which gear you are in......50
Set up works great- only selling because I am planning to upgrade to a th400.
Matt
Old Oct 13, 2006 | 08:55 AM
85irocz28's Avatar
Car: 1985 Iroc Z
Engine: 383 carbed
Transmission: Th 400 tci super street
Axle/Gears: 3:42 9 Bolt
can u check with spohn to see if it hooks up to a stock setup?
Old Oct 13, 2006 | 12:31 PM
graphicideas1's Avatar
intrested in shifter - send me photos to graphicideas1@msn.com
Old Oct 14, 2006 | 07:18 PM
I just took shifter out today. I took pics with it installed and separate. I'll email you tomorrow (wife has to do it-I don't know how to send pic).
As for spohn, I will try to contact him, but can't promise you when due to schedule.
If you want- Spohn Performance, Inc. or tech line 1-717-273-6004
Matt
Old Oct 14, 2006 | 11:12 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
What trans is this crossmember for?
Old Oct 15, 2006 | 09:46 AM
pics sent
crossmember is direct bolt-on for 700r4 and 9" rear end. Anything else would have to be checked with spohn
Matt
Old Oct 15, 2006 | 09:59 AM
will take b&m shifter - let me know how to pay
Old Oct 16, 2006 | 09:22 PM
payment sent
morrow
Jan 13, 2024 12:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
