355 SBC - HSR setup - Will Seperate
up for sale is my built 355, only has about 100 miles on the rebuild, if that...minimal runtime
Motor consists of:
1989 Corvette 350 2 Bolt Block - bored .030 over making it a 355
Corvette 113 Aluminum Heads - Ported
New Pistons/Rings and rods
Crank Turned .010"
New Crank/Cam Bearings
High Volume Oil Pump
High Flow Water Pump
Comp Cam 276HR - 224/230 Duration at .050"...503/.510 Lift
Heads:
New Manley High Lift Valves - Single grove on top of the valve allows for more lift
Comp Cams 1.450 Daul Springs - bored spring pockets
Shaved To Approx. 9.8 to 1 Compression
Port Job
Crane Energizer Roller Tipped Rockers 1.6 Ratio..Making Lift .536/.543 approximately
its a very stout motor yet streetable, my engine builder said its capable of 400 horse all though it was never dynoed, definately will get a car into 12's with the right suspension mods. Comes with all the accesories if you want them. Power steering, waterpump, altenator, starter.
asking $2000 for the long block with all the accessories
Intake:
Holley Stealth Ram (deribbed and polished)
Holley Fuel Rails W/Adjustable Regulator
Accel 26# Injectors
TPIS Twin 58MM Throttle Body
Stainless Steel Braided lines and adapters for stock fuel lines
Comes with distributor and accel coil
asking SOLD for the intake
Pictures:
Intake when it was Brand new http://memimage.cardomain.net/member...42_40_full.jpg
Heads http://memimage.cardomain.net/member...42_37_full.jpg
http://memimage.cardomain.net/member...42_38_full.jpg
Shortblock http://memimage.cardomain.net/member...42_42_full.jpg
http://memimage.cardomain.net/member...42_43_full.jpg
http://memimage.cardomain.net/member...42_44_full.jpg
http://memimage.cardomain.net/member...42_45_full.jpg
http://memimage.cardomain.net/member...42_46_full.jpg
Motor in the car http://memimage.cardomain.net/member...42_51_full.jpg
http://memimage.cardomain.net/member...42_52_full.jpg
thats all the pics I have as of right now, I can get up to date pics if you please, but it looks just like the last few pics I posted, just outside of the car.
Motor consists of:
Crank Turned .010"
Heads:
Port Job
Intake:
Accel 26# Injectors
Pictures:
i'm not going to seperate that much as of right now. I'm just seperating the motor into 2 right now, induction system and long block.
I might decide to part out the intake further down the road, but not right now, sorry...
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
well if you are willing to separate, ill take the fuel lines and such lemme know if you decide to, thanks
my mistake guys...i know 'will seperate' is vague, but what i meant is i will seperate the intake from the long block
i don't want to seperate it anymore than that right now...sorry
so if you want parts off the intake, you have to buy the complete induction setup..
just to clearify things up there
Car: 91 z28
ok ill trade you my intake, tb and fuel rails + cash for your set up lol,
yes it will, its a direct replacement. I have all the vacuum taps in it....if you have vortec heads, you'll obviously need the vortec stealth ram..but yes, this intake is made for the L98 heads...i have aluminum L98 heads..so its a direct bolt on, plug and play..
$2250 for the longblock with all the front mounted accessories
$750 for the intake (I can't go any lower on the complete induction, your getting alot for $750, its over 50% off retail)
anytakers?
anytakers?
recieved the payment for the intake today. I still have the long block left, the distributor, an accel coil, and the accel 26# injectors...so that is still up for sale
its just a stock style distributor, but its the small cap style, made for the remote mounted coil. I'll do $40 shipped for it, but I have to contact the person who bought the intake to make sure he doesn't need it..let me know if you want it
I know it is getting close to christmas and everybody has presents to buy. But I need to get rid of that motor soon. So the price is $2000 O.B.O. I will entertain any reasonable offers. No low balling though...Thanks guys
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
