355 Eaton supercharged & T56 4 Sale
Car: 90 Camaro
Engine: 418 LS3 whipple charged
Transmission: Magnum T56 w/ Street Twin
Axle/Gears: 3.27 9 bolt
I am ready to start selling these parts off so start making offers. I am selling off my 355 Blower engine and parts, contact me for more info. All of my machine work and assembly was done at Auto Rons in Davenport, IA.
1. Dart Pro1 200 cc aluminum heads ported and polished Brand new $1400
I have over $2000 in these heads they have been bolted on and never fired.
PBM 2.02 & 1.60 valves, 1.550 springs and 10 degree titanium valves and locks. Viton valve seals and 3/8s studs and ARP head bolts
2. LT-4 Crane self aligning roller rockers $200
3. Manley push rods $60
4. Polished aluminum center bolt valve covers $100
5. Comp Cams Custom ground hydraulic roller cam .544 I .556 E 230 I 236E 114 lope seperation.New $270
6. Roller timing chain New $100
7. 355 Short Block 87 roller block .030 over and blueprinted it is a 2 bolt block that has been strapped for added strength 5300 miles since freshening. Lunati rods, Lunati flat top forged pistons, Gm steel crank, Melling oil and pickup, Moroso 6 quart pan, Moroso windage tray, GM quick change cam kit and new GM balancer. $1800 I have over $3000 in this short bock
8. SLP 1 ¾” headers & y-pipe w/ 3” single cat adapter. Jet hot coated, never fired since coated. Wide band O2 port also welded in. Air tube removed and welded closed $450
9. Rebuilt distributor w/ new cap & rotor, Accel 300+ ignition and coil, full set of Delphi racing wires, wiring harness $200.
10. Holley commander 950 part number 534-120 w/ communication cable and software, new. $500 I paid $650.
11. LT1 style Mini starter $75.
12. I also have all of the serpentine brackets and accessories up for grabs, all power steering pump, altenator, 5000 miles on them and are in very nice shape (no a/c parts). Stewart stage 2 water pump reverse rotation brand new $350
13. Custom Eaton M112 supercharger setup. All parts are new and custom built. It is very similar to a Magnacharger setup. This unit is not completely finished As Is $1400. If completed $2800
I will entertain offers and package prices, I will sell everything for $7800, Everything except #13 $5200, item 1-7 for $3800, item 10-11 with tpi harness converted for commander for $850.
Thanks for looking
Thanks for looking
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Specs on custom cam? And This Holley commander, is it part number 950-101? Does it include wire harness? What about map sensor?
Car: 90 Camaro
Yes, it is a Holley Commander but it is just the ecm, software, and communication cable. You can reuse your stock harness by just repinning it, it also just uses a stock map sensor. It is part number 534-120 is is about $650 with the cable. The cam is .544 I .556 E 230 I 236E 114 lope seperation. These specs are from memory and I will verify them later. These numbers are correct.
Car: 90 Camaro
You are correct on what the JTR conversion is. I don't have a good picture of it handy. Everything is still installed in the car and my wife has the camera with her. If you are interested let me know what you would like a picture of.
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
What does the Eaton setup consist of? I am from the Quad Cities, and visit there all the time. I also may be interested in the torque arm and clutch, but I have a 2 piece rear so I cannot use the flywheel. If you cannot seperate I understand.
Car: 90 Camaro
Sorry, I can't seperate the clutch setup, I will post a picture of the motor later it will show the blower the way it was a couple of weeks ago. I have a brand new eaton m112 (same as lightning,cobra,magnacharger) intake, injectors, fuelrails. Currently finishing intercooler, idler pulleys, and throttle body/intake plenum.
Car: 90 Camaro
This picture is a little old but it gives the general idea
Car: 91 GTA
Engine: 377ci
Well the supercharger setup is a bust for me. I am running ETEC heads which have the vortec style intake bolt pattern. I was hoping you had ducted it somehow.
Car: 1987 pontiac firebird formula ws6
Engine: chevy 400 cubic inch V8
Transmission: turbo 350
pics and price for the Accel 300+ ignition and coil. also what distributer were you using with this? pics of that distributer if it works with the ignition box and coil. thanks. my email is imnottomhull@yahoo.com
Car: 90 Camaro
The ducting is partially complete, the picture I posted is older and not complete. I really don't want to start selling off some of the smaller items until I have sold the trans, heads or short block because if they don't sell I will be finishing the build as I had originally planned. I can still get a few pictures if you still would like them, the dist is a 1990 unit with new ignition module, pick-uo coil, msd cap and rotor?
Thanks,
Thanks,
Thanks,
Thanks,
Car: 90 Camaro
Here are the ignition pictures. This set up has the harness with it to plug directly into the stock harness.
oh i dont have a stoch harness, actually i dont have one i got rid of fuel injection. thanks though.
ambainb
Apr 25, 2016 09:21 PM
92projectcamaro
Jan 18, 2016 08:00 AM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
toronto formula
Nov 10, 2015 06:17 AM
