Ive got some more stuff thats gotta go!
91-92 TPI Speed Density harness. Great condition, nothing cut. INCLUDES MAP sensor. $200 plus shipping.
Next is an S10 manual steering box. $50 plus shipping.
Last for now is a factory GM 327 forged crank. Uncut journals. Casting number 4577, small journal, 3.25 stroke. Light surface rust, pics make it look alot worse than it is. $100 plus shipping.
Parts located in NJ 08052, and are also available for local pickup or delivery!
Bump!
Open to reasonable offers!
What vehicle is the harness out of, camaro or trans-am?
Was told it was out of a Camaro from a very well respected member here that I had bought it off of. I just dont remember his name!
Alright here are the shipping weights for anyone that would like to calculate postage!! Would be coming from NJ, 08052
Steering Box: 26lbs including packaging.
Crank: 60lbs including packaging.
Ill do a flat $15 shipping on the harness anywhere in the lower 48. Elsewhere will be extra.
You should be able to lay out the harness and if the battery connection is on the drivers side it's a Firebird harness, Camaro will be on the passengers side.
Ah good point... battery connection is on the passenger side, same side as the MAP. So definetly Camaro!
This was just pulled from my 91 Z28 parts car.
If it looks just like mine is a Camaro harness.
I'm not jacking your thread just helping ID your harness.
Yup, looks the same! Thanks man!
Appreciate the help!!
No problem, just remember me if I buy those 113 heads from you.
Will do!
WheelsUp84z
close
- Join DateJul 2005
- Locationcurrently Jacksonville NC
- iTrader Positive Feedback100
- iTrader Feedback Score(2)
- Car91 z28
- Engine383 sbc, 88mm turbo a2w IC, CSU 750
- Transmissionth-400 PTC 4000 stall
- Axle/Gearsford 9" 3.55 gear
- Liked:0 Times in 0 Posts
is the steering box for sale? if so ill take it, pm sent!
