tpi setup for sale cheap complete
Car: 1994 firebird
Engine: 427ci lsx bowtie block
Transmission: tremec t56 micro edged gears
Axle/Gears: Strange dana 60 with racing spool
1987 tpi setup out of a GTA with a 350 and an automatic. converted to speed density to run a ram air setup with no maf. no cracks or leaks, injectors are excelent no leaks with those either. come with base intake, runners, plenum, throttle body, fuel rail, injectors, all gaskets, distributor, complete wiring harness, and 730 ecm everything worked mint can ran excelent the only reason i took it out was to give my mom my engine to put in her 85 iroc which was a carb setup so i had to take the tpi off and put a carb and edelbrock intake on it to make it work for her car. i will money back gaurantee this setup works excelent and all sensors are included. call nate at 508-523-1627 if your interested you can look at it if you are anywhere near zip code 01527 which is millbury mass. i have other tpi parts for sale as well to go with this setup for a little extra such as nos spray plate and adjustable fuel pressure regulator and k and n throttle body air filter all in great shape and ready to.
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
Is this the same one that was on E-bay that said it came out of a 92 for a starting price of $350.00?
Car: 1994 firebird
350 tpi for sale complete cheap
no it isn't the same one. i had a 92 tpi that i sold to someone after the auction ended we made a deal so i wouldn't have to pay ebay or paypal. this one is out of my trans am 1987 like i said. it has the cold start injector and everything the other one didn't
Terrell351
Jun 13, 2021 01:13 PM
Sanjay
Aug 12, 2015 03:41 PM
